jonathanch
Dec 18, 2019Aspirant
Orbi RBR40 dropping WiFi 4 times a day?
Is there a way to track my WiFi conectivity to see if my Orbi is dropping the WiFi. I am using Verizon Date 4 times a day when we are at home and supposadley connected to WiFi.
Dec 18, 2019Guru - Experienced User
jonathanch wrote:Is there a way to track my WiFi conectivity to see if my Orbi is dropping the WiFi.
I'm not sure what you mean you're using verizon date.
Firmware on the orbi?
Is it only wireless device dropping or wired devices as well?
What modem are you using?
jonathanch
Dec 20, 2019Aspirant
Only wireless is dropping as far as I can tell.
- plemansDec 20, 2019Guru - Experienced User
Can you tell that devices are disconnecting from the orbi?
Is it all devices having this issue or only one?
Or you've just noticed that periodically when you should be on wifi, you're phone is using data?
What zyxel modem is it?
- badbrainDec 20, 2019Aspirant
I'd recommend manually updating your firmware. The automated check doesn't seem to identify that there's new firmware available.
- jonathanchDec 20, 2019Aspirant
I am only conserned with my phones using data.
EMG341S-B10A
- FURRYe38Dec 20, 2019Guru - Experienced User
You modem may already have built in router and wifi, if so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jonathanch wrote:I am only conserned with my phones using data.
EMG341S-B10A
