labrie85
Nov 29, 2020Aspirant
Orbi RBR40 Drops Connectivity
I have a RBR40 Router running version V2.5.1.22. I have 2 satillites connected, both are RBS20 running firmware verson V2.5.1.16. Started loosing connectivity about 2 weeks ago. Thought it was a co...
Nov 29, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
labrie85
Nov 30, 2020Aspirant
FURRYe38 wrote:Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
First off, thank you for your help.
1. ISP has confirmed today that everything is configured properly on their end. They doubled checked the MAC and Serial # of the modem and it's properly setup.
2. Their's no splitters. It goes directly from the pole to the house through a NEW lightning arrestor with correct filter.
3. Not sure what they used for cable. It's comcast and they ran a new cable from pole to house and from lighning arrestor to the inside. The cable from outisde to inside is maybe 5-10 feet run at most.
4. The modem was reset today when I talked to comcast. (Still dropping on the router side of things)
5. I logged in locally to the Netgear CM1000 router and the uptime has been 8 hours. So it appear's their is internet coming into the house and their's no issue on that side of things. It now appears to be an issue between the modem and router.
6. My house is 2000 square feet
7. Distance between the router and satalites is no more than 30 feet, probably any where between 5-15.
8. 2.4 ghz ch is Auto and 5ghz ch is 48. I will change the 2.4 ghz to 1 and I changed the 5 to 44. (It appears wifi is working fine within the house, when the internet dropps connectivity our wifi devices stay connected)
9. Beamforming and MIMO are now enhabled.
10. A factory reset has not been performed. I guess that's my next solution. Start from scratch.
11. I have disabled any of the settings you suggested.
Wish me luck!
- FURRYe38Nov 30, 2020Guru - Experienced User
labrie85 wrote:First off, thank you for your help.
7. Distance between the router and satalites is no more than 30 feet, probably any where between 5-15. <this is too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Wish me luck!
