MattSC
Mar 16, 2021Guide
Orbi RBR40 Drops Internet only on PC devices
Desperate - We have Orbi router RBR40 and 1 Sat RBS40 It has been fine for 2 + years - all through 1 year on 2 students and 2 home workers -- All of a sudden the internet connection is dropping but ...
PeteNH
Mar 18, 2021Aspirant
I have an Orbi RBR40 with 2 satellites and all has been great for over 2 years. Two days ago it updated to the latest Firmware version 2.6.2.104 for the Router and 2.6.2.2 for the 2 satellites and we've started to experience the exact same issue described in this thread. Hardwired connections continue to work without issue. The wifi drops very frequently each day, although, some existing connections continue. For example, Roku steam continues. Our daughter's Zoom class continues but she's unable to open any other tabs due to no connection. Rebooting the router fixes it for a few hours but then it repeats!
- vajimMar 18, 2021Master
PeteNH wrote:I have an Orbi RBR40 with 2 satellites and all has been great for over 2 years. Two days ago it updated to the latest Firmware version 2.6.2.104 for the Router and 2.6.2.2 for the 2 satellites and we've started to experience the exact same issue described in this thread. Hardwired connections continue to work without issue. The wifi drops very frequently each day, although, some existing connections continue. For example, Roku steam continues. Our daughter's Zoom class continues but she's unable to open any other tabs due to no connection. Rebooting the router fixes it for a few hours but then it repeats!
just curious...what do you mean when you say..."Two days ago it updated to the latest Firmware"
what was the process?
- PeteNHMar 18, 2021Aspirant
Sorry, to clarify, I was in the Web based Admin portal on the "Firmware update" screen where it showed there was a new firware version available for both the Router and 2 satellites. I then clicked Update All. So it wasn't automatic without me knowing but was simply applying the latest version (vs doing a Manual Update).
PeteNH wrote:Sorry, to clarify, I was in the Web based Admin portal on the "Firmware update" screen where it showed there was a new firware version available for both the Router and 2 satellites. I then clicked Update All. So it wasn't automatic without me knowing but was simply applying the latest version (vs doing a Manual Update).
Thanks
I only mention that because some believe you have no choice to update, but in reality you do. It wouldn't be so precarious if NG did a better job with their firmware testing.
Thanks again for the honesty.
