MattSC
Mar 16, 2021Guide
Orbi RBR40 Drops Internet only on PC devices
Desperate - We have Orbi router RBR40 and 1 Sat RBS40 It has been fine for 2 + years - all through 1 year on 2 students and 2 home workers -- All of a sudden the internet connection is dropping but ...
AmishBob
Mar 19, 2021Initiate
Guys, I think it is an issue with the time synchronization going off post DST. I've been having this same issue since DST, but I didn't realize that was when it started until I read this post. I went into the admin section for timezone and it was already off by minutes after a restart. I think it is an issue with the supposed 'netgear NTP'. I manually changed it to us.pool.ntp.org and we'll see if 1. it stays connected and or 2. the time sync issue goes away.
RS356
Mar 19, 2021Tutor
I was advised to just turn off auto DST and all is still working. For some reason, it would not let me put in another NTP server no matter what I tri
AmishBob wrote:Guys, I think it is an issue with the time synchronization going off post DST. I've been having this same issue since DST, but I didn't realize that was when it started until I read this post. I went into the admin section for timezone and it was already off by minutes after a restart. I think it is an issue with the supposed 'netgear NTP'. I manually changed it to us.pool.ntp.org and we'll see if 1. it stays connected and or 2. the time sync issue goes away.
ed
- MattSCMar 20, 2021Guide
Managed to get back in - Firmware rollback corupted password and question answers - solution - reset via serial number - leave answers to questions blank ! all good ..
followed idea posted by AmishBob - and using NPT server he identified - lets see how it goes - All my troubles started with DST - time was first thing I looked at but I guess just after a reeboot it looked reasonable.
- MattSCMar 22, 2021Guide
So after changing time server - ran okay for ~36 hours then dropped again - reeboot at 11pm Sunday - Better so waitining to see what happens
Hows it going for you after turning off DST
- RS356Mar 22, 2021Tutor
MattSC wrote:So after changing time server - ran okay for ~36 hours then dropped again - reeboot at 11pm Sunday - Better so waitining to see what happens
So you have unchecked DST and put in a new NTP server? Mine has been fine except when I thought I would check to see if enabling DST would work but it didn't. Dropped my PC but other things kept working as before
