Willam11
Apr 13, 2020Initiate
Orbi RBR40 Flashes (not pulsates) white frequently
Hi, I bought a refurbished Orbi RBR43 kit and set it up 4 days ago. It is sitting behind a comcast modem/router combo plugged into the ethernet port. Serial #: 50U77953005A2 Firmware version: ...
- Apr 13, 2020
IWhat mode is your modem router working in? Bridge or Router mode? If it has a built in router, This would be a double NAT condition which isn't recommended. Would be a cause of the RBR flashing WHITE possibly.
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Willam11
Apr 15, 2020Initiate
Thank you, 10/10 advice. I plan to do that in a bit.
For anyone else experiencing this issue, it can also be resolved by setting a reserved IP address for the Orbi.
I understand comcast can sometimes block you from enabling bridge mode, for example if you are using xFi features, so setting a reserved IP might be some peoples only option.
Once I set a reserved IP for the Orbi from my comcast router web control, I no longer have Wifi drops / flashing white light.
Thanks, @Blanca_O ! I will definietly be turning the Comcast router/modem into bridge mode.
Apr 15, 2020Guru - Experienced User
Ya, some ISPs block user access to there modems. Glad you were able to get your working.
Enjoy. :smileywink:
