Waldy1983
Aug 29, 2020Follower
Orbi rbr40 flashing problem
Cant set up my orby, keeps doing this, and cant see my orby over my wifi network and cant set it up, this ir what it does
Flashing white
Pulsing white
Flash of green and red and then repeat, Any help would be great
Flashing white
Pulsing white
1 Reply
- MstrbigMaster
Flashing white
Pulsing white
Flash of green and red and then repeat, Any help would be greatTry this, may or may not work for stubborn routers.
Unplug Orbi router from the wall, leaving the Power suipply plugged in and the power button in on position.
After 1 to 2 minutes, press and hold the reset button and plug in the router, still holding the reset button.
When the router power flashes red, let go of the reset button and let the router come back up.
The power light should be normal and hopefully the top ring will be pulsating white and ready to reconfigure as if it came out of the box.
