jamescosta
Aug 04, 2019Aspirant
Orbi (RBR40) getting different speeds than modem
Hi there! My current setup is: Cable internet (800mbps down, 30mbps up) -> modem -> RBR40 -> 3 satellites around the house When I check speeds (via Ethernet) at the modem level, I’m ...
jamescosta
Aug 05, 2019Aspirant
Great call and thanks for the response, FURRYe38!
My ISP modem is a Hitron CODA-4582. The FW version I have on my RBR40 is 2.3.1.58 (notably, when I try and "Check for updates" via the iOS app I get an error). The speed numbers I quoted before were from the speed test in the iOS Orbi app. I haven't done a factory reset at all and am trying to see if it's something else before I do (I have a RBR50 I was going to swap the RBR40 out for anyway so will end up doing it at that point).
When I hardwire into my RBR40 (ethernet to my MBP) and use Speedtest's desktop app, I get 700mbps down (Fast.com gives me 770mbps down). When I do the same thing into my ISP's modem/switch, I get 930mbps down (Speedtest desktop, Fast.com gives me 1.1gbps).
Sitting beside the RBR40 and using my iPhone on wireless, I get 200mbps down (Speedtest iOS app, 320mbps on Fast.com). Seems like a pretty massive discrepancy? I recently upgraded my Internet speed to gigabit from 200mbps and before was getting 200mbps down without fail... is there a throttling (or something) that happens above that?
Aug 06, 2019Guru - Experienced User
Always use the stand alone speed test app from Ookla. Don't use the Orbi app or the RBRs speed test. These two don't give accurate speed results.
Try a factory reset on the RBR and setup from scratch with out enabling the built in speed test on the RBR, traffic meter or any access controls. Speed test with a wired PC directly connected to the RBR.
Wifi will have different results. Wired is preferred testing initalially.
- jamescostaAug 10, 2019Aspirant
Thanks again FURRYe38! Sorry for the delayed reply, weekends are always easier to find time to dedicate to this. (If you're ever in Toronto, beer is on me!)
I swapped out by RBR40 for an RBR50, updated a bunch of firmware, and I'm presently getting 830mbps+ down (via Speedtest's desktop Mac app, Fast.com is giving me 1.2gbps) when hardwired.
When I connect via wireless (sitting beside and connected to the RBR50), I'm taking a pretty decent hit (but it's hard to say what's "normal" so I'd love your thoughts): 530mbps down (Speedtest's iOS app, Fast.com is giving me 520mbps down). Any ideas, or is this expected?
- FURRYe38Aug 10, 2019Guru - Experienced User
You can use wifi sweetspots spp on there mobile devices to see what connection rate there devices connection at the Orbi. Remember, this is only a connection rate between the device and the Orbi. Not actual throughput data flow. Also the max rate on Orbi systems is 866Mbps.
Data flow rates depend on client side Mfr design and support of there devices. Most current devices max out at around 400-600Mbps. New phones may be able to see near 900Mpbs...I'm not sure though. MFrs would have this information.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Mmmm Beeer. :smileyvery-happy:
That's such a great app - extremely useful and will be helpful with some tweaks I want to make to where my satellites are located. It looks like I'm getting an average of 550mbps with that when I stand beside the router, and an average of 800mbps when standing beside the RBS50 (that seems strange).
I've got 3 satellites (RBR50 is on main floor): RBS50 (main floor by back window, 20ft away with a [plaster and lath] wall separating (for the backyard)), RBS40 (in the basement, directly under the router), and an RBW30 (upstairs, directly above the router). We have a pretty old house so the walls definitely hurt us a bit which is why we have so many.
I assume the difference in the throughput data flow (i.e. tests through Fast, Speedtest) and the connection rate (i.e. tests through Wi-fo Sweetspots) are primarily due to servers and ISP, then? Mainly what I'm after at this point is: is this normal, or should I be trying to tweak more?
Thanks again!
