marpkr
Sep 11, 2019Follower
Orbi RBR40 help!!
I'm new to this thread but I'm in desperate need! I have spent way too many hours trying to connect the Orbi RBR40 to the spectrum modem and having no luck! The satellite are turning blue but the othe...
Sep 11, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain should be disabled for ethernet connected RBS, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
When connecting the satellites via wired back haul, connect 1 satellite first via wireless, then once you get the BLUE led on top of the satellite, connect the LAN cable between the satellite and Orbi router. Wait for up to 5 minutes for the top LED to turn BLUE. Once this is done, do a IP address reservation for the satellite ON the Orbi router. Save and apply.
Connect all follow on satellites using the above method.
Once all is connected and running. Place satellites in remote locations with there LAN cable connected and turn ON.
Be sure that Daisy Chain is disabled when you have the satellites connected.
