orbeefan66
Mar 24, 2018Tutor
Orbi RBR40 integration with Google Assistant
Hi, I have an Orbi RBR40 with 2 satellites Firmware shows as 2.0.0.56 with no update available. I have just set up my Netgear account to work with Google assistant and whilst I can "talk to netgear"...
- Apr 03, 2018
Managed to sort this out, slightly embarrassing really, there is remote management which I had enabled but there is also remote access which appears to be on the Genie app only. Once that was turned on Google and Netgear play nicely together! Thanks for all help and advice.
Steven_Belfast
Mar 24, 2018Apprentice
Are you able to remote manage the Orbi using Orbi app on 3/4G ?
I assume you have enabled remote management.
- orbeefan66Mar 25, 2018Tutor
Hi, thanks for the response, remote management is enabled and I can connect and login via my phone on 3/4G,
- Steven_BelfastMar 25, 2018ApprenticeHi , is your Netgear account the same email address as google ?
Hi, yes, both the same email address, thanks
