orbeefan66
Mar 24, 2018Tutor
Orbi RBR40 integration with Google Assistant
Hi, I have an Orbi RBR40 with 2 satellites Firmware shows as 2.0.0.56 with no update available. I have just set up my Netgear account to work with Google assistant and whilst I can "talk to netgear"...
- Apr 03, 2018
Managed to sort this out, slightly embarrassing really, there is remote management which I had enabled but there is also remote access which appears to be on the Genie app only. Once that was turned on Google and Netgear play nicely together! Thanks for all help and advice.
orbeefan66
Apr 04, 2018Tutor
Thanks for the heads , have you tried it?
Apr 04, 2018Guru - Experienced User
Working well for me on my 40 series model.
Factory reset and set up from scratch is needed.
