ajagenx
Apr 26, 2021Tutor
ORBI RBR40 Intermittent disconnect
Help! After 2 years of zero issues my RBR40 router with plugin mesh orbi is having horrible intermittent connectivity issues. Called internet service provider and no issues detected on their end. ...
Apr 26, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
ajagenx
Apr 26, 2021Tutor
Thank you for replying! I have a Spectrum modem and I believe it's model is either E31u2v1 or PC15. There is not much identification anywhere on the modem and other info besides FCC and S/N etc.
The modem/router are about 30ft. and 1 floor away from satellite. Think rectangle ranch house 1800 sq ft. modem/router in basement on far retangle side. mid way in basement are steps and top of landing is the satellite (has always been in that location).
There are about 2 other neighbor wifi visiable and nothing seems changed there.
Your list of disabled I could only find in the user manual about Daisy Chain and Fast Roaming. All of which are not even listed as something to enable / disable when following the user manual while logged on to my account. So nothing there to disable.
ok here is where I'm lost. The channels. it was set to Auto for 2.4G and 48 for 5G. What does these mean? I see them in the app but nothing in the user manual. So just change my 2.4g to one of the channels you suggested?
- FURRYe38Apr 26, 2021Guru - Experienced User
ajagenx wrote:Thank you for replying! I have a Spectrum modem and I believe it's model is either E31u2v1 or PC15. There is not much identification anywhere on the modem and other info besides FCC and S/N etc.
FYI, basements are not recommended places for wifi source devices like the RBR. Concrete and steell will inhibit signal travel.
Check the RBRs web page for advanced features and settings using a web browser.
ok here is where I'm lost. The channels. it was set to Auto for 2.4G and 48 for 5G. What does these mean? I see them in the app but nothing in the user manual. So just change my 2.4g to one of the channels you suggested? Check the RBRs web page for advanced features and settings using a web browser.
Does the RBRs top ring LED appear when you see this intermittent disconnect?
- ajagenxApr 27, 2021Tutor
Morning- I still have not executed all the steps you suggested. However while working on them I noticed the satellite showed a frimware update due so I executed that. The app only shows firmware updates on the router so when logged via desktop it displayed both devices. I have had zero issues since. First time in about 3 weeks. If it starts again I will go back to finish executing your list. i appreciate your help!
- FURRYe38Apr 27, 2021Guru - Experienced User
Good to hear. Please mark your thread as solved so others will know.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemPlease mark your thread as solved so others will know.
Enjoy. :smileywink:
