Julielawton
Dec 15, 2021Follower
Orbi RBR40 is blocking my Macbook air
My Macbook air has recently been blocked by my orbi RBR40 router. I am receiving a message every time I try to connect to the internet that says this device is blocked by access control in the rout...
CrimpOn
Dec 15, 2021Guru - Experienced User
The most obvious method is to disable Access Control in the Orbi web interface, Advanced Tab, Security Menu... Access Control.
Julielawton wrote:
My Macbook air has recently been blocked by my orbi RBR40 router. I am receiving a message every time I try to connect to the internet that says this device is blocked by access control in the router. Does anyone know how to unblock my computer. All of my other devices are working fine. How do I get to access control to unblock?
- Abdul-HakkimMar 22, 2022Aspirant
Orbi killing my MacBook internet connection. MacBook showing Wi-Fi signal but no internet
orbi app so many times I pause and reconnect ,no use
whem I open Orbi app on my iPhone it is showing pause even I didn’t
note: firmware is latest
Extremely thankful
it works for me
