Zootness
Feb 01, 2019Aspirant
Orbi rbr40 is dead after 6 months
My Orbi RBR40, about 6 months old, seems to have bricked itself. A couple weeks back it just stopped working. The green power light was on, but networking was not functioning. I turned it off for a ...
Feb 02, 2019Guru - Experienced User
What FW is currently loaded?
Was there any top LED colors on the top of the Orbi?
Zootness wrote:
My Orbi RBR40, about 6 months old, seems to have bricked itself. A couple weeks back it just stopped working. The green power light was on, but networking was not functioning. I turned it off for a while, went through setup again and it worked. However tonight it happened again and this time it isn't coming back. Pressing reset with a paper clip and holding it for a minute didn't do anything (light didn't turn amber). I can't install new firmware since the unit is a brick and I can't connect to it. I need some support.
Zootness
Feb 02, 2019Aspirant
No lights. Only power light. No idea of the firmware, since I can't connect to it to check. Pretty clear it is dead. I'm trying to do an RMA, but they don't have any replacements in stock. :(
- michaelkenwardFeb 03, 2019Guru - Experienced User
I have never needed to do a "hard reset" on an Orbi. But on a Netgear router this is the procedure:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
You have nothing to lose.
- ZootnessFeb 03, 2019Aspirant
Did that multiple times, but thanks for the suggestion. This thing is deader than slab of bacon.
