SinmanTX
May 12, 2019Aspirant
Orbi RBR40 issues updating Samsung devices
I have a very strange issue that has recently started. Not sure when it started but I cannot seem to correct this issue. The issue is, I cannot get some of my Samsung devices to connect to the firmar...
- Jun 15, 2019
Just to update this post. I installed an older router/ap in place of the Orbi and I was experiencing the same issues. I contacted my provider and swapped out the modem. Changing the modem (only a modem) has corrected this issue.
Thanks for all of the feedback.
May 13, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Try setting 1.1.1.1 and 9.9.9.9 DNS addresses on the RBR...
- SinmanTXMay 17, 2019Aspirant
FURRYe38,the modem is
ARRIS DOCSIS 3.0 / PacketCable 2.0 Touchstone Telephony Modem
HW_REV: 1
VENDOR: ARRIS Group, Inc.
BOOTR: 2.2.0.45
SW_REV: 9.1.103J8TW1.SIP.PC20.TW
MODEL: TM1602AP2Since this is a modem only, I am running the Orbi in Router mode.
As for the DNS, I have already tried that. I have also tried adding the Samsung device to the DMZ.
- FURRYe38May 17, 2019Guru - Experienced User
Is this the only devices that are having problems? Do other devices have full internet access?
Do you have any parental controls enabled like Circle or Armor? Disable them if you do.
So far this is all that I can see that's not working. I have a seperate circle device that I have disconnected (same issue with or without it connected) I have the Circle feature off in the Orbi.
If I tether the Samsung tablet to my phone (on 4G) it connects to the software update server and if I take these devices to another network they connect. Next step is to replace the Orbi with my old AP and see what happens (it will connect so I don't even know why I'm wasiting the time).
I've also packet captured the deivce that does not work and the one that does work when performing the update and they both seem to send broadcast's to 224.0.0.251
