SinmanTX's avatar
SinmanTX
Orbi RBR40 issues updating Samsung devices
I have a very strange issue that has recently started. Not sure when it started but I cannot seem to correct this issue. The issue is, I cannot get some of my Samsung devices to connect to the firmar...
  • SinmanTX's avatar
    SinmanTX
    Jun 15, 2019
    Just to update this post. I installed an older router/ap in place of the Orbi and I was experiencing the same issues. I contacted my provider and swapped out the modem. Changing the modem (only a modem) has corrected this issue.
    Thanks for all of the feedback.
