SinmanTX
May 12, 2019Aspirant
Orbi RBR40 issues updating Samsung devices
I have a very strange issue that has recently started. Not sure when it started but I cannot seem to correct this issue. The issue is, I cannot get some of my Samsung devices to connect to the firmar...
- Jun 15, 2019
Just to update this post. I installed an older router/ap in place of the Orbi and I was experiencing the same issues. I contacted my provider and swapped out the modem. Changing the modem (only a modem) has corrected this issue.
Thanks for all of the feedback.
chathamws
Jun 02, 2019Aspirant
I can confirm this issue also exists on the RBR50. Neither my Samsung Galaxy Note 9 or Galaxy Tab S4 can connect to Samsung update servers when connected to the Orbi hotspot at home. It works on any other wifi hotspot (including my old wifi router). I have replaced the Orbi with a new one at my local Best Buy store, performed several factory resets, tried using Orbi without the Sattelite turned on to no avail. Additionally I am also having performance issues when the Orbi is put in AP Mode (I have a support case open for that issue already). I wonder if these problems are related in the Orbi software somehow. Its been a frustrating experience with this Mesh wifi system and am regretting not going with either a Cisco or Ubiquiti access point.
Blanca_O
Jun 02, 2019NETGEAR Employee Retired
Hi chathamws
Our engineers are looking into this issue. We would like to request for debug logs. Please check your inbox.
Blanca
Community Team
- chathamwsJun 16, 2019Aspirant
OK, I believe the problem is elsewhere after doing more troubleshooting. I think it was coincidental that this problem with samsung update started occuring around the same time I installed the RBK50. I have performed packet captures with my PFSesne firewall/router and it looks like samsung is blocking some of Spectrum's network. I will need to reach out to Spectrum Cable to further troubleshoot.
- FURRYe38Jun 18, 2019Guru - Experienced User
Thanks for letting us know.
chathamws wrote:OK, I believe the problem is elsewhere after doing more troubleshooting. I think it was coincidental that this problem with samsung update started occuring around the same time I installed the RBK50. I have performed packet captures with my PFSesne firewall/router and it looks like samsung is blocking some of Spectrum's network. I will need to reach out to Spectrum Cable to further troubleshoot.
