SinmanTX
May 12, 2019Aspirant
Orbi RBR40 issues updating Samsung devices
I have a very strange issue that has recently started. Not sure when it started but I cannot seem to correct this issue. The issue is, I cannot get some of my Samsung devices to connect to the firmar...
- Jun 15, 2019
Just to update this post. I installed an older router/ap in place of the Orbi and I was experiencing the same issues. I contacted my provider and swapped out the modem. Changing the modem (only a modem) has corrected this issue.
Thanks for all of the feedback.
Blanca_O
May 19, 2019NETGEAR Employee Retired
Hi SinmanTX
Our support team is looking into this issue and would like to work with you. Please check your inbox.
Blanca
Community Team
SinmanTX
Jun 15, 2019Aspirant
- FURRYe38Jun 15, 2019Guru - Experienced User
Enjoy. :smileywink:
SinmanTX wrote:Just to update this post. I installed an older router/ap in place of the Orbi and I was experiencing the same issues. I contacted my provider and swapped out the modem. Changing the modem (only a modem) has corrected this issue.
