robertkat's avatar
robertkat
Follower
Oct 16, 2020
Orbi RBR40 Keeps Rebooting
My router keeps rebooting. We loose internet, I walk over to the router and it is flashing white ring, in about 2 min we are back online. It just started doing this a couple days ago, and does this 5-10 times a day now.
  • Has a power off for 1 minute then back on been performed since last update?
    Is Armor or Circle enabled?
  • My RBR20 did this soon after I bought it. I tried everything (resets, different power supply, change settings, etc.) but it would just spontaneously reboot about once or twice a day - yours is more frequent.
    I ended up opening a case with Netgear and they sent me a replacement router (albeit a USED one with a really old serial #!), and that one has been solid, except for the fact that the speed drops after a few days and I have to manually reboot it, but that's another story...
    Probably a defective unit. I hope yours is still under warranty. If not, I would call it a loss and buy a non-Netgear router. I've had two different Netgear models (Nighthawk and Orbi) and both have given me trouble.
