apetrov
Jan 11, 2022Aspirant
Orbi RBR40 loses internet connection minutes after factory reset
I have Orbi router RBR40 with 2 Orbi Wall Plug Satellites (RBW30). Recently it lost my internet connection (even though I could connect via the cable). I talked to my ISP support and they confirmed...
- Jan 15, 2022
I looks like the issue was with my internet provider. I had to put my router under firewall or connect to another router.
apetrov
Jan 15, 2022Aspirant
Jan 30, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
