DiscoSquid
Apr 30, 2020Aspirant
Orbi RBR40 Max Speed
Hello, I have an Arris SBG8300 modem/router with an Orbi RBR40. I put the Arris is bridge mode and connected Orbi. I did this as I recently upgraded to Gigabit internet. The maximum speed I am getti...
DiscoSquid
I followed all instructions and still only pushing about 500 download
May 01, 2020Guru - Experienced User
I would contact NG support about this to see if they have more help and information regarding this.
https://www.netgear.com/support/#
There have been others posting about the 20 and 40 series with 1G ISP services. I don't have these models. I do know my 50 series supports near 900Mbps speeds.
- DiscoSquidMay 01, 2020AspirantI did a full factory reset and tweaked some other settings and was able to get the gigabit speed I pay for. However now I have a new issue. My third satellite is producing 150mbps. The satellites are all within 30 feet of each other. I understand I won’t get gigabit speed from the satellite but I feel 150 is a little low. Any ideas?
- FURRYe38May 01, 2020Guru - Experienced User
With in 30 feet maybe too close. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. More distance between maybe needed. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Disable Daisy Chain if enabled. Power OFF all other RBS and just test 1 RBS.
Disable the wifi radio on the mobile device for 5 seconds while near the RBS, then re-enable the wifi radio. Then re-test the speed.
- DiscoSquidMay 01, 2020AspirantOkay I’ll try that. I should add. I’m hardlined in at the second satellite idk if that helps.
