DiscoSquid
Apr 30, 2020Aspirant
Orbi RBR40 Max Speed
Hello, I have an Arris SBG8300 modem/router with an Orbi RBR40. I put the Arris is bridge mode and connected Orbi. I did this as I recently upgraded to Gigabit internet. The maximum speed I am getti...
May 01, 2020Guru - Experienced User
With in 30 feet maybe too close. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. More distance between maybe needed. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Disable Daisy Chain if enabled. Power OFF all other RBS and just test 1 RBS.
Disable the wifi radio on the mobile device for 5 seconds while near the RBS, then re-enable the wifi radio. Then re-test the speed.
DiscoSquid
May 01, 2020Aspirant
Okay I’ll try that. I should add. I’m hardlined in at the second satellite idk if that helps.
