IraW
Mar 19, 2021Aspirant
ORBI RBR40 NEEDS FREQUENT REBOOT
I have an Orbi RBR40 with two Satellites, connected to a Surfboard (Arris) SBG6782-AC modem (built in WiFi disabled), on a Spectrum cable internet. The specifications are as follows: Hardware Ver...
CrimpOn
Mar 19, 2021Guru - Experienced User
IraW wrote:The problem is that for the past week, I have been losing WiFi connectivity a few times a day,, but everything else works OK.
Can you please expand on this:
- "Losing WiFi connectivity" means that the Orbi stops broadcasting the WiFi SSID.
A phone, for example, will switch to LTE because it no longer has a WiFi connection?
When a device looks for WiFi systems, this Orbi no longer appears? - "Everything else works OK" means that there are devices connected to the Orbi with ethernet cables which remain in operation using the internet?
- IraWMar 19, 2021Aspirant
- REPLY:The SSID shows on my devices, but no internet connection
A phone, for example, will switch to LTE because it no longer has a WiFi connection? - REPLY: If I turn off the WiFi on my phone when I lose internet connection, it connects to the carrier's 5g network
When a device looks for WiFi systems, this Orbi no longer appears? - REPLY: The Orbi SSID shows, but it says "No Internet Connection"
- REPLY: My VOIP phone and FAX still work, but sometimes my Win 10 PC loses internet when I lose the WiFi internet connection. Cycling on and off the power with the power button (I leave it off for about 30 seconds), or use the router's soft reboot, then everything works fine for a several hours, then it stops again. The lights on my Surfboard Modem always show that I am receiving and sending data.and rebooting the modem has no effect. The problem is with the RBR40.
Thank your for your assistance.
- CrimpOnMar 19, 2021Guru - Experienced User
(I hate to be like the doctor who says, "there is something 'going around' right now. You probablyl have it." but......
There have been a chorus of complaints since Daylight Saving Time that Orbi routers begin failing to resolve Domain Names.
When this happens, computers connect to the Orbi, but every attempt to connect to some internet resouce by its Domain Name (such as google.com) fail to resolve into an IP address. There must be at least a dozen open posts on the forum right now about this issue.
The root problem is that something in the Orbi firmware has gone whack-o because of Daylight Saving Time and a side-effect is that DNS resolution is failing.
There is a great post on the forum about various ways users are trying to address the problem:
I am currently trying a solution suggested by a Netgear engineer:
Navigate to the Orbi web interface, Advanced Tab, Advanced Settings, Traffic Meter, and uncheck the box "Enable Traffic Meter" and then click on "Apply". It has been a number of hours since my Orbi exhibited the problem. When I get to more than 24 hours, I will declare it "fixed."
This week has been absolute hell for my domestic tranquility. "The ***** internet is down AGAIN. Fix the damn thing!!!!"
- mediccbyMar 25, 2021Aspirant
My system has been doing the same thing fow a little over a week now. I just want this fixed.
