Atmtran
Mar 06, 2020Aspirant
Orbi rbr40 new printer can’t find the WiFi network
I just brought a new Canon printer TS8370 and the printer can’t search my home WiFi network. Network around my place is able to find. Anyone has any ideas what is the possible issue? Thanks.
- Mar 08, 2020
Yes, different WiFi channels in different countries is one of those things I never think about. The printer is probably programmed to look for channels 1-11 and you live in a location that allows 12 & 13. With the Orbi set to "Auto", it could very well see that 12 or 13 has less radio interference and pick one of them.
Mar 07, 2020Guru - Experienced User
Get into a USB to LAN print server device that you can connect the usb printer to.
- JetdriveMar 07, 2020Luminary
Rather that spending more money, I would contact Canon and see if they can help you getting your new printer connected. If they can't, I would suggest returning it and getting another printer that is easier to set up.
- CrimpOnMar 07, 2020Guru - Experienced User
Having read the User Manual some more, I think the answer can be found on page 235:
http://gdlp01.c-wss.com/gds/6/0300036856/01/TS8300ser_OnlineManual_Win_EN_V01.pdf
i.e. Go to WiFi setup, select the WPS (WiFi Protected Setup) method (push button) and follow the directions on the tiny screen.
- FURRYe38Mar 07, 2020Guru - Experienced User
Ensure the printers FW is updated as well.
