orionrph
Jan 17, 2020Aspirant
Orbi RBR40 No wifi when computer is off
I'm a networking newbie and need some help. When my computer is off, when wifi is off as well. I've got my Orbi connected to the modem and my computer connects to the wifi wirelessly. There are 18 dev...
orionrph
I have connected the computer to the Orbi with an ethernet cable (disconnecting the computer to the wifi, of course), but the same problem exists. When I turn off the computer, the wifi network goes down.
I setup the Orbi with the same computer I'm having this issue with. I feel it is something I did when I setup, but I have no clue what it is.
Thanks.
Jan 17, 2020Guru - Experienced User
You need to ensure your modem is configured as suggested and then configure the orbi accordingly.
If the modems wifi is running as well, this could be causing problems.
I recommend you try option ## for your Orbi and your modem.
orionrph wrote:I have connected the computer to the Orbi with an ethernet cable (disconnecting the computer to the wifi, of course), but the same problem exists. When I turn off the computer, the wifi network goes down.
Thanks.
- orionrphJan 17, 2020Aspirant
I have AT&T coming on Monday. I will have them turn off the wifi radio on the modem. I will then go from there.
