Sudhir14
Oct 10, 2020Aspirant
ORBI RBR40 not connecting to internet
Hello, Need help on this. It is working fine from the past 1.5 years. Not sure what happened 3 days ago when power is gone for 5 mins. Since then my router is not connecting or giving me internet...
Mstrbig
Oct 11, 2020Master
Sudhir14 wrote:Hello,
Need help on this. It is working fine from the past 1.5 years. Not sure what happened 3 days ago when power is gone for 5 mins. Since then my router is not connecting or giving me internet. Modem is working fine. Wired from modem is providing me the internet. Tried to setup as new through orbi app. No luck. Seeing white ring on the orbi. I tried all possibilities such as rebooting modem, 2 satellites. Tried new setup option via app. On the app I am getting unable to join the network ORBI. I don't see my ORBI network on my phone. Currently using my old router for the time being which is working just fine. Need help with this ORBI RBR40 to bring it back on trackIf youy have not done so
If you have not done so, perform a factory reset on the RBR40, reboot the ISP modem and perform another setup using the app.
Sudhir14
Oct 11, 2020Aspirant
Thanks. I just did earlier this morning. After factory reset, it worked. Later updated the firmware. All set. For satellites I did later in manual mode by downloading the FW.
