Huntzman
Jun 11, 2018Guide
ORBI RBR40 Not Connecting to new Modem
I have an ORBI RBR 40 (main unit w/ 2 satelites). Last night a huge storm came through and blewout my modem. I replaced it this morning and went to reconnect it, but now the ORBI won't link. Have tri...
- Jun 15, 2018
Huntzman wrote:
I'm going to try that tomorrow st_shaw - I already put away the cable and my brain is toast right now. I'm pissed about not being able to game tonight and vent my rage *LOL*
It's killing me that I had zero issues before, and now nothing but........
Right now I have the Orbi (yellow port) wired into the LAN1 port, so tomorrow I will disable the wireless setting on the Zhone and see if that corrects things.
Sounds good. After disabling wireless on the Zhone make sure you log into the Orbi interface and switch from Router mode to Access Point mode. It's under Advanced, Advanced Setup, Router/AP Mode.
Huntzman
Jun 11, 2018Guide
Just some follow-up information.
The new modem is a Zhone (Local Telephone / Internet Provider). It's the same type as the old one.
I've tried several times to re-install / reboot. The Orbi appears, but there is no communication between it and the modem.
I am able to connect directly to the modem.
- st_shawJun 11, 2018Master
If the storm blew out your modem, and the Orbi was wired to it, maybe the Orbi was damaged also.
- HuntzmanJun 11, 2018Guide
No, the only part of my modem that blew was the 'wireless' component, so they told me I would have to swap that out if I wanted to use the wirless feature, which my desktop used. My kid was hard wired to the Orbi and he still had a connection. The connectivity issue didn't arise until I swapped the modems out.
Ok, but that doesn't seem to make sense. If you had an Orbi, then you normally should not have been using the wireless on your old modem. In that case, you should stil be able to use the old modem even if the wireless was non-functional.
Anyway... If your new modem is configured the same as your old modem, you shouldn't need to change anything on Orbi, except maybe cycle power.
