Huntzman
Jun 11, 2018Guide
ORBI RBR40 Not Connecting to new Modem
I have an ORBI RBR 40 (main unit w/ 2 satelites). Last night a huge storm came through and blewout my modem. I replaced it this morning and went to reconnect it, but now the ORBI won't link. Have tri...
- Jun 15, 2018
Huntzman wrote:
I'm going to try that tomorrow st_shaw - I already put away the cable and my brain is toast right now. I'm pissed about not being able to game tonight and vent my rage *LOL*
It's killing me that I had zero issues before, and now nothing but........
Right now I have the Orbi (yellow port) wired into the LAN1 port, so tomorrow I will disable the wireless setting on the Zhone and see if that corrects things.
Sounds good. After disabling wireless on the Zhone make sure you log into the Orbi interface and switch from Router mode to Access Point mode. It's under Advanced, Advanced Setup, Router/AP Mode.
Jun 13, 2018Guru - Experienced User
192.168.1.1 or www.orbilogin.com
Huntzman
Jun 13, 2018Guide
Should the ORBI be connected to the WAN port on the router or one of the LAN slots ?
- HuntzmanJun 13, 2018Guide
Okay, so when I hook everything up and try and access the system through the laptop, it tells me that my user name and password are incorrect, then it asks me two security questions, but the only problem is we have never filled out any security questions for this system........
I just tried running and re-running the install, but it keeps coming back that the system is already installed and there is no internet connection
