debcunning
Jun 09, 2021Aspirant
orbi RBR40 repeated threat detected alerts
Since yesterday I've haven gotten nearly 200 "threat detected" alerts from Orbi. They all seem to be tied to my husbands iphone. I just updated the firmware, not sure if that will solve the problem...
Jun 09, 2021Guru - Experienced User
Is Armor enabled on the RBR?
- debcunningJun 09, 2021Aspirant
Yes, Armor is enabled. Looks like it expires in september, but it is enabled now. Graph shows almost no activity until yesterday and then a crazy spike on the one device
- FURRYe38Jun 09, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armorI would review what this one particular device is doing and what is loaded on it that maybe causing problems.
Good Luck.
Thank you!!
