brentriddell
Mar 20, 2020Aspirant
Orbi RBR40 Router and RBW30 Satellite - Router reboots itself randomly several times a day
Hi, I've had the Orbi RBR40 Router and 1 x RBW30 Satellite for almost 2 years and recently (in the last 3 days) the router has been rebooting itself regularly throughout the day (5-6 times per day) a...
- Mar 20, 2020
I'm trying running without the Satellite for a while and see if it makes any difference 🤷‍♂️
brentriddell
Mar 24, 2020Aspirant
After running without the Satellite for a few days, I can say the situation has improved greatly, I've had no reboots (which is a huge relief after a week of reboots every hour or so and trying to work from home) ... but now what do I with the Satellite? :( I'm out of warrenty and not really sure what could be causing it from the Satellite end - Already tried a factory reset ... anyone else have an experience like this?
Mar 24, 2020Guru - Experienced User
