Noroddveien
Jul 05, 2020Apprentice
Orbi RBR40 router set up as AP to RBR50 router
Hi, I have an Orbi AC3000 wifi sytem which includes the RBR50 router, RBS50 satelite, RBS50Y satelite and RBW30 satelite (see photo). I´m trying to set up a supplemental RBR40 router as a simple ...
Noroddveien
Jul 06, 2020Apprentice
My RBR50 router has SSID=ORBI3000 while my RBR40 (AP mode) is configured with SSID=RBR40. So, from what I understand, RBR50 and RBR40 will compete for satelite connections depending on location of satelites. BTW, RBS50 satelite is connected to my router via ethernet backhaul. My RBR40 is ethernet-connected to RBR50 via 2 switches and is located in an annex adjacent to our house.
tomschmidt
Jul 06, 2020Virtuoso
Make sure that the 2 network switches between your RBR50 router and RBR40 (AP) for the ethernet backhaul are not "green" switches. For some reason, the wired backhaul will not work on power-saving green switches. There have been multiple threads on the community forums regarding this, such as https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-Compatible-Switches/m-p/1913276
You might be able to use female-to-female RJ45 connectors where your switches are for this wired backhaul connection to your AP, making it work like a single long network patch cable.
- NoroddveienJul 06, 2020Apprentice
My switches are standard "non green" gigabite switches. In addition, my physical network layout makes it impossible to include a single long network patch cable between RBR40 and RBR50. I guess my best option is to sell the RBR40 and get a new satelite (connected via ethernet backhaul). Shame though, as I already have the RBR40 and a new satelite is quite expensive here in Norway.
- FURRYe38Jul 06, 2020Guru - Experienced User
As long as the SSIDs are different between the RBR50 and RBR40 and the RBSs are already synced to the RBR50, then they should remain connected to the RBR50 only.
Yes, I agree FURRYe38, the satelites should remain connected to the RBR50 only. I don´t understand why the RBR40 screws up my network. I´ll have to do do some more "trial and erroring" after the summer. Right now it´s time for summer vacation:-)
