djdavis
Dec 31, 2020Follower
orbi RBR40 set up - moved to new home, do i have to reset the system
Hi all!
I had my Orbi RBR40 set up at my old home and worked well. I have moved to a new home and having problems getting it to work. I am not so savvy on networking stuff.
1. I have Spectrum WIFI and on a speed test can pull >200Mbps downloads but my son still has a lag on his PS4 - the Orbi should help that right?
2. How do I reset it to work in my new home? Do I have to reset the whole system and if so how do I do that?
3. Also, for set up I plug it into the modem I have and skip the Spectrum router all together correct? I have my Wifi through Specturm cable.
THANK YOU for any advice!
1 Reply
djdavis wrote:Hi all!
1. I have Spectrum WIFI and on a speed test can pull >200Mbps downloads but my son still has a lag on his PS4 - the Orbi should help that right? Depends.
2. How do I reset it to work in my new home? Do I have to reset the whole system and if so how do I do that? You don't have to if this is a new system or cureent system and your moving to a new place. Up to you.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
