Mogg
Feb 25, 2018Tutor
Orbi RBR40 system working fine - but have one windows 10 pc that will not connect
Have a new (installed yesterday) RBR40 and 2 satellites. Its working fine - and have two imacs, a pc using windows 8, the chromecast and even the vpn working happily together.
But having trouble connectioning a pc running on windows 10.
Oddly it worked happily for a few hours, but then stopped - and no amount of forgetting networks or installations and reboots and obvious firewall changes have worked.
Orbi sees the pc and lists it as connected and allowed - meanwhile the pc shows the orbi as connected, but says no internet is available through it.
Any ideas?
- jvasanth1984Virtuoso
Hi Mogg,
Check for any static IP assigned on that PC and remove it.
- MoggTutor
Thanks - seem to have solved it (permanently who knows??!) by removing the vpn app from that pc. Reinstalled and now seems fine - lets hope it lasts!
Hi Mogg,
Good to know that your issue is resolved.
