Ran_P
May 17, 2021Aspirant
Orbi RBR40 "the default gateway is not available"
I'm using RBR40 Router with RBS20 satellites. It works fine at the first few days. Today, it keep letting my disconnected, and can be fixed by win10 troubleshooter automatically with the error report...
Ran_P
Thank you so much!
Mine is happenning while running. I have 3 devices, 1 Win10 desktop, 1 mobile phone, 1 Win10 laptop, they are facing this problem together. Once it happens, 3 devices have no internet connection at the same time(still have wifi from orbi, just no internet); And once 1 device troubleshooted this problem with Win10 automatic troubleshooter, other devices will also be recovered.
CrimpOn
May 18, 2021Guru - Experienced User
Before running the network troubleshooter, can you open a Command Window and type this command:
ipconfig /all
Then type the same command after running the troubleshooter.
(see attached image) The question is what your system shows for gateway before and after. My PC is connected through the ethernet port. If your PC is connected through WiFi, the gateway will appear under that network adapter.
