JC3228's avatar
JC3228
Follower
Jul 10, 2020
Orbi RBR40 to RBS20 wired issue's
Hello,
   I'm not very familiar with wireless setup and modes and what not. I've had my Orbi 40 and satellite 20s setup for a while but i had one that would always drop due to being in a seperate building from the main house. I ended up finding a CAT 5E cable going to both buildings and I put ends on them and I'm trying to make one of my satellites wired. It appeared to work for a day although it had an orange halo but now it appears to not connect at all. What should I be changing to get this one satellite to work being wired? Thank you
Jake
1 Reply
  • plemans's avatar
    Easy check? get a short cable and move it by the router and connect it. Maybe the cable ends are bad, maybe its only a cat5 cable (not cat5e), or even maybe the cable is bad.
