parramp
Jan 07, 2021Aspirant
Orbi RBR40 VERY SLOW WITH BOTH ETHERNET AND WIFI
My Orbi RBR40 is operating very slow. I have a 1GBS Fiber connection so I get 700-800 MBS both upload and download from the line in. Through the router and ethernet to my pc, I am getting speeds...
Jan 07, 2021Guru - Experienced User
What gateway are you connected to?
Make sure to have access controls, qos, parental controls, traffic monitoring all disabled. If they were enabled, disable and reboot the router.
parramp
None of that was enabled, and I did disconnect the power for 5 min and let the router reboot.
