ddigler
May 13, 2021Aspirant
Orbi RBR40 w/ 2 sats. My z-wave hue lights are always going unresponsive please God someone help me!
I am offering $1k USD to anyone who can help me. To be certain that statement is a JK but if someone could actually help me I might actually do it lol. I am pretty tech savy and have been PLAGUED by ...
CrimpOn
May 13, 2021Guru - Experienced User
ddigler wrote:My wife is at Best Buy picking up a hue bridge as I type. I don't know if controlling the lights with this will help or not butI"m trying anything at this point.
Was fascinated by the review by Craig Moore on the Amazon Echo Plus:
https://www.amazon.com/All-new-Echo-Plus-2nd-built/dp/B0794W1SKP?th=1
He mentions a difference between Zigbee and Z-Wave. and that the Phillips Hue lights do some things, but not other things unless there is a Phillips Hue hub.
My thought is that there appears to be no need to have more than a single Z-Wave hub because the individual devices 'mesh' with each other. Have no idea what happens if there are 4 hubs in a single house.
My guess is that Orbi has zero to do with the problem. All my lights being only one color (Daylight white) and at maximum brightness, I lack any competence with "Hue".
CrimpOn
Have read more, and remain ignorant.
- Both Amazon Echo Plus and Philips Hue use Zigbee, not Z-wave. So I was incorrect to even mention Z-wave.
- Zigbee uses 2.4GHz frequencies which cover exactly the same band as 2.4G WiFi. (Z-wave uses 900mhz.)
- It appears that some Zigbee hubs are "frequency agile". Found an article describing how the Samsung "Smart Things" Zigbee hub is configured with a Zigbee channel at the factory and cannot be changed.
- There are tons of articles on the web about interference between Zigbee and 2.4G WiFi.
- Most of the articles do not take into account that Netgear's Orbi system assigns the same 2.4G channel to all Orbi units. If the setting is "Channel 1", then they are all on channel 1.
- I have found nothing about Amazon Echo Plus Zigbee channel settings. Agile? Settable? No idea.
- What I can say is that the 2.4G default ("Auto") means that the Orbi periodically surveys the WiFi neighborhood and switches 2.4G channels. My guess is that this might wreak havoc with the Philips Hue bulbs.
- I also have no idea if the Amazon Echo Plus can be told to "turn off Zigbee" on some units but leave it on for other units.
It seems to me that the best advice will come from some combination of Amazon Echo techies and Philips Hue techies.
Maybe involving something like setting the Orbi 2.4G WiFi channel and the Zigbee channels where they cannot overlap and cannot change. (no "auto")
- ddiglerMay 14, 2021Aspirant
I really appreciate the input Crimp.
To me your theory is the most plausible as it explains clearly how I could intermittently lose 5-8 lights out of the clear blue and in the absence of any obvious cause. If my Orbi router, which is set to 'auto' channel selection for 2.4ghz wifi, decides to switch itself and the (2) sats, for whatever reason, understanding the documeted interference between zigbee and 2.4ghz wifi, this could explain the dropping lights.
On the Amazon Echo Plus support forum, a user nice enough to try to help me holds a different theory and subsequent thoughts regarding how to fix:
'No, zwave and zigbee are low power wireless mesh networks. It's very rare that wifi will interfere.
As I mentioned, you have a zigbee network and need to strengthen your zigbee mesh. If you strategically place zigbee smart plugs throughout your home, it will create a robust zigbee mesh network and your bulbs will stabilize.'
So, I've got a couple suggestions, but to me Crimp, yours sounds closer.
Figuring the i. Echo Plus can not deactivate its zigbee signal & ii.it does not allow one to change zigbee channel:
Should I start by forcing Orbi to a specific 2.4 wifi channel and see how it goes for awhile? What channel should I use for Orbi?
- CrimpOnMay 14, 2021Guru - Experienced User
That advice is straight out of the Zigbee instructions. Unlike what the industry calls "mesh" in terms of WiFi systems (which is actually a master/slave relationship), it appears that Zigbee is a true "mesh" where each of the devices communicates with devices near it. If there is a gap in the mesh, communication is more difficult so the recommendation is to have Zigbee devices in lots of places.
Despite more searches, I cannot find any information on Amazon Echo Plus Zigbee channels. This post seems to indicate that the Philips hub is able to define which channel to use:
https://www.reddit.com/r/tradfri/comments/9mnlwr/changing_zigbee_channel_due_to_interference/
This is where my total lack of hands on experience with Zigbee is frustrating. My sense of it is that Zigbee devices will follow the hub to a new channel unless they have to be paired again.
So there are now two criteria for selecting which 2.4G WiFi channel to use:
- To avoid interference from all the neighbor WiFi systems, select a channel that is not dominated by neighbors' WiFi systems.
- Then set the Philips hub to a Zigbee channel that does not overlap with the Orbi WiFi.
Note the comment by JDRoberts in this post:
https://community.smartthings.com/t/faq-networking-and-reducing-channel-interference-between-wifi-and-zigbee/40159
The context of that post regards Samsung Smart Things hubs which cannot be changed once they leave the factory, but the principle remains the same. If Orbi WiFi is set to any channel from 1-6, then set the Zigbee to the high end. If Orbi is set to any channel from 6-11 (North America. to 13 in the rest of the world), then set Zigbee to the loweest channel.
- ddiglerMay 15, 2021Aspirant
This is all good information Crimp thank you.To your point, I have not been able to locate any info in terms of what zigbee chanel echo plus uses or whether or not it is a static channel or can vary. Whereas the hue bridge allows one to establish a specific, static zigbee channel to use, the Echo Plus does not (atleast I am not aware of an option to accomplish this).
Understanding that your theory relates to Orbi auto switching 2.4ghz channels, thereby causing sudden zigbee overlap/interference and subsequent lights failing, all at once:
Is there a way to identify which 2.4Ghz channel Orbi is currently using while set to 'auto'? Does it make sense to track this channel from time to time and certainly after a light failure to see if I can identify the channel that is screwing up the program?
Or just buy a few zigbee repeaters? But this option seems like a bit of a bandaid IMO...
