Shahab
Apr 21, 2020Apprentice
Orbi RBR40 WiFi disconnects daily
Hi everyone, My Connection: Arris TM1602 Cable Modem (Charter) -> Orbi RBR40 router -> 2 RBW30 Satellites Looking to get help with my Orbi system as I am experiencing my WiFi dropping daily, often mu...
Shahab
Jun 02, 2020Apprentice
Hi,
After more than a month of problems, I was finally able to talk to a supervisor from the 1st level team who escalated the issue to level 2 supervisor, who then likely escalated to Level 3. The level 3 rep then sent me a replacement router, upgrading me to a RBR50 from the RBR40. I had a few disconnects when I first got the RBR50, but for the past few weeks it’s been running without interruption.
Make sure you have the LAN/WAN packet capture enabled and running from the Orbi debug page. Then when you get a disconnect, save the packet capture (if it’s still running) and send it to Netgear. Try to keep a tally of when the disconnects happen, date and time, what device you noticed it on, etc.
guilloryjc
Jun 02, 2020Aspirant
Thanks for the response.
What a pain, I have the RBR50 and its happening 2-3 times a day. My 3 months are up and now they want $90 to do what I assume will not help.
Did you pay or were you covered ?
- FURRYe38Jun 03, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
guilloryjc wrote:Thanks for the response.
- ShahabJun 07, 2020Apprentice
I belive you get 1 year of support via e-mail and 90 days via phone, right?
Shahab
- CrimpOnJun 07, 2020Guru - Experienced UserAlas, no. 90 days of support. One year of warranty. How a customer demonstrates failure in order to get warranty coverage is a mystery to me.
