ReluctantITsupp
Jan 10, 2021Aspirant
Orbi RBR40 wifi speed
I just upgraded from ATT 300 to ATT 1 gig fiber service to the house but max wifi download speed from Orbi RBR40 is 300Mbps. Can I get more?
Setup:
ATT router (Arris BGW210) > Orbi RBR40 (AC2200, FM V2.5.1.22). There are also 2 RBS20 satellites (FM V2.5.1.22) placed in other parts of house.
Ethernet cable from iMac into Orbi RBR40. Speedtest on iMac using ethernet via RBR40 is 930Mbps.
Approx 12 devices on wifi network (computers, phones, TV)
Question - iPhone 8 placed 2ft from Orbi RBR40 only gets 300Mbps download. Can I get more - possibly via reconfiguring the Orbi? I am not technical so can't remember how to get to Orbi router settings. Or is it time to buy a new wifi system?
Thanks
What are your wired speeds with a wired PC connected to the RBR?
Most iphones and WiFi 5 devices will max out at around 400-500Mbps due to the antenna design, 2x2. Even my 12 Max gets around 400 to 500ish speeds. You'll not see anything near 900Mpbs on 5Ghz AC wifi. Wired you should.
- ReluctantITsuppAspirant
Wired download speed with a wired PC connected to the RBR = 930Mbps
Is there a way to increase the RBR wifi speed from 300Mbps to the 400-500Mbps max? Or is 300Mbps the best I should expect?
Thanks
Can try reviewing these:
Your getting around normal speeds for wifi devices.
