confundida
Aug 15, 2023Aspirant
Orbi RBR40 will not connect to new Cable modem
We recently upgraded our cable to one gig. We have tried to connect our RBR40 to two different modems, a Netgear NightHawk, and an ARRIS SB8200. In both cases the modem successfully connected to our ...
- Aug 16, 2023
Glad you got something working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
michaelkenward
Aug 16, 2023Guru - Experienced User
confundida wrote:We have not tried resetting, as I'd hoped to avoid going through the Orbi setup again.
That would seem like the first thing to try, especially when you are playing with different modems. Who knows which settings the router has picked up in that messing around?
Failing that, you could see if you can get the RBR40 to go through the Internet setup routine with the browser graphical user interface (GUI).
Remember, when setting things up, the order is important.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
