garytmoulder
Dec 19, 2018Follower
Orbi RBR40 wired connections fail to connect to the internet
I can establish a WIFI connection to my ORBI and connect to the internet. When i try to connect through a wired port, it fails to connect to the internet. i have rebooted the ORBI multiple times an...
randomousity
Dec 19, 2018Luminary
So, just to check a few things:
- On the device (laptop?) you're connecting via ethernet, do you have the ethernet port enabled, and do you have have DHCP enabled on that port as well (assuming you're running the Orbi as your DHCP server) and, if you don't use DHCP, do you have the proper settings configured on your laptop for ethernet use (e.g., an unused IP address in the correct range, with the correct subnet mask, your Orbi as the default gateway, and one or more DNS servers)?
- Have you tried using a different ethernet cable in case the cable is bad, and made sure the cable is securely seated in both the laptop's ethernet port as well as the Orbi's LAN ethernet port?
- Have you tried another device (e.g., a second laptop) to make sure the issue is with the Orbi and not the laptop?
- Does the laptop connect to the ethernet properly (link lights by the ethernet port, settings show that a connection is detected, and configuration), and the issue is just that you don't have internet access, or do you also not have LAN access?
- When connected over ethernet, try disabling wifi to ensure the device is only using ethernet, and then try accessing something on your LAN. If nothing else, try the Orbi's configuration page (probably 192.18.1.1 if you haven't changed it). Can you access the Orbi over ethernet?
- When you connect to the Orbi over ethernet, you aren't using the ethernet cable that connects the Orbi to your modem, are you? In other words, there's one ethernet cable going from the Orbi's yellow internet port to the modem, and then a second ethernet cable going from one of the Orbi's numbered LAN ports to your laptop?
- Assuming you have at least two Orbi devices (a router and a satellite), do you have the router connected to the modem (as opposed to having the satellite connected to the modem)?
- Do you have the correct port on the router connected to the modem?
- Have you attempted to connect the laptop to a different port on the Orbi
- Are you running the Orbi in router or AP mode?
- Do you have a second router on your network at the same time (whether it's your modem, or another router) handling routing functions, and, in particular, DHCP?
