garytmoulder
Dec 19, 2018Follower
Orbi RBR40 wired connections fail to connect to the internet
I can establish a WIFI connection to my ORBI and connect to the internet. When i try to connect through a wired port, it fails to connect to the internet. i have rebooted the ORBI multiple times an...
michaelkenward
Dec 20, 2018Guru - Experienced User
To add to the comments from others, can you say what happens when you try to connect through a wired port?
What is the connection? A Windows PC?
What prompts do you get?
A simple "wired connections fail" is too vague for useful diagnostics.
