Stimar
Dec 01, 2019Tutor
Orbi RBR40 with RBS40 slowness issues Until the system is rebooted ?
Hi All, Can someone help/guide me how to fix this problem with the slowness that i can see with my router? In this setup i have: Model ORBI RBR40 (router and satelite rbr40 and rbs40) FW 2....
- Jan 08, 2020
Hi All,
Well I have to start with apology to NetGear, the issue is fixed, router si doing great again.
I've chenged all available cables, RJ45 connectors from the ISP cable and so on...
It turned out to be RJ45 power protection module on the existing UPS (the module which is protecting the my route from the ISP cable for electrical surge) and i'm guessing a contributing factor will be the cable bending to much due to the UPS location ...
When i've changed the surge protection module from old UPS everything is fine now.
BR
Stimar.
Dec 02, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
Has a factory reset and setup from scratch been performed since last update?
- Retired_MemberDec 02, 2019
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
Most will agree...factory reset is for lost paswords.
