cagintx's avatar
cagintx
Follower
Jul 05, 2020
ORBI RBR40 with two satellites slow speeds
Network speed at router tests at 450+ Mbps which is consistent with my service.  Throughtout home whether I'm next to router or one of two satelittes speed maxes out around 45 Mbps.  Devices tested are MacPro laptops running Catalina and multiple iPhone 8s with latest release.  Worked fine until my support contract expired.  Is this the way they get you to pay for support?
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    Is wired speeds good at the router?
    T
    ry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
