Lewis558
Sep 21, 2019Aspirant
Orbi RBR40
Orbi won’t allow for streaming of any kind despite saying it has internet access and I cannot update social media’s as they time out due to not being able to update. Turn WiFi off of phone or devices ...
Lewis558
I’ve had this happen with the other network completely disconnected.
To be honest, no idea how to open a command prompt
ekhalil
Sep 21, 2019Master
Do you use Windows 7, 10 or MacOS?
- Lewis558Sep 21, 2019AspirantI would be using a MacOS
- ekhalilSep 21, 2019Master
In MacOS you need to start Terrminal.
To open it, either open your Applications folder, then openUtilities and double-click on Terminal, or press Command - spacebar to launch Spotlight and type "Terminal," then double-click the search result.
- Lewis558Sep 21, 2019AspirantGot it. Sitting at computer waiting for next step now
