tadatech
Nov 14, 2019Aspirant
Orbi RBR40
I would like to turn all Wifi/AP from my Orbi and go strictly with UBNT unifi controller and APs. But for some reason when I turn off everything in the wireless settings the AP is still up and runnin...
CrimpOn
Nov 14, 2019Guru - Experienced User
This qualifies as a "strange request". The entire point of Orbi is "mesh WiFi". If the goal is to deploy Ubiquiti WiFi, the most logical thing to do would be remove the Orbi entirely and install a Ubiquiti router designed to work with Ubiquiti WiFi. (Alas, I Googled "UBNT" and found nothing, so I have no idea what the goal is.) Or, there are any number of decent routers available for under $100.
What a person could do, would be to:
- Stop broadcasting SSID on both 2.4G and 5G
- Set the 2.4G and 5G channels to the most heavily congested possible, and thus away from the channels to be used by Ubiquiti
- Disable Guest
- Use telnet commands to drop the transmit power on 2.4G and 5G to the lowest possible
https://community.netgear.com/t5/Orbi/Further-Reduce-the-Transmit-Power-in-Orbi/m-p/1672260
This would reduce the Orbi to a "so so" router and there would be some anemic, invisible WiFi networks.
Apologize if I have missed something obvious and gone wandering off in the wrong direction.
tadatech
Nov 15, 2019Aspirant
I understand your concerns. The client originally has the orbi system in place but we found that the ubnt wifi system is better. We plan on saving them some money and using the orbi strictly as a router. We've found we can turn it off via the Chrome Dev mode.
