rayterry
Jul 04, 2018Apprentice
Orbi RBR40/RBS40 (V2.1.4.16) mesh network drops connection to Apple iMac
I have an ongoing issue where my Orbi RBR40/RBS40 (firmware = 2.1.4.16) mesh network drops the connection to an Apple iMac on OSX v10.13.5. No issues like this previously with my old Apple Time Capsu...
- Jul 12, 2018
The changes that apparently fixed my connection issue...
In orbilogin.com, Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
In orbilogin.com, Advanced WAN Setup changed MTU Size(in bytes) to 1492.
Powered down the Orbi. Powered down the cable modem. Restarted both.
rayterry
Jul 07, 2018Apprentice
Thanks. Those setting are disabled and I've gone from 1 to 6 to 11. 11 seems to be working the best thus far as there are no strong chan 11 signals nearby. Re Macs, I have 3 in the same room and only 1, the iMac, has the issue (others are a Macbook Pro and a Mini). I guess it could be a problem with the iMac, but there were no issues like this when I using the Time Capsule. So why did I switch you may ask... TCs have been discontinued by Apple, but you probably know that already. Thx for your ideas...
Jul 07, 2018Guru - Experienced User
Can you lan wire connect the one iMac and see if it does anything different?
- rayterryJul 08, 2018Apprentice
Yes, I have cables long enough to try that. I'd just have to walk over a lan cable across the living room for 5 or 6 days to see if things would be better, and I suspect they would. I'm trying chan 6 again, just for grins, so maybe after that test completes. Thx again for trying to help.
