chaos2751
Dec 21, 2019Aspirant
Orbi RBR43 with TDS Fiber
Hi all, I’m currently having internet issues with TDS fiber service. I pay for 300mb fiber but keep getting ~150-160mb from Orbi. I’ve tested hardwiring directly from Cat5e outlet to laptop, which ...
Dec 21, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Swap LAN cables between the ISP modem and RBR.
- chaos2751Dec 21, 2019AspirantThanks for prompt reply.
It’s running the lastest firmware (V2.3.5.30), and I think it’s connected to an ONT that TDS provides and mounted on a wall in basement. Is there still Double NAT condition?- FURRYe38Dec 21, 2019Guru - Experienced User
if the ONT has a built in router, then yes will present a double NAT condition. IF not, then single NAT is present.
- chaos2751Dec 21, 2019AspirantIt’s hard for me to tell if the modem is ONT or ONR ‘cause I’m no expert. I couldn’t attach any photos here.. no brand name shown on the cover, but I’ll try my best to briefly describe it:
1 reset pinhole, 3 Lan ports (one of them is connected to a cat5e cable), 2 phone ports, and a power input. The indicators including 1 POWER, 1 CPU, 1 WAN, 1 PHONE, 4 LAN.
Please let me know.
- chaos2751Dec 24, 2019Aspirant
I just found out that it is a "Calix" ONU (716GE-I), and I'm not sure if it's configurable for bridge mode..
