bmxsteve
Jul 28, 2020Aspirant
Orbi RBR450/RSR50 Not Recognizing Wired Backhaul
Hello - looking for some guidance with a very simple question. I have an Orbi RSR50 that has been connecting wirelessly to the RBR50...I decided to hard wire the two devices via ethernet. However, af...
- Jul 29, 2020
Thanks for your help. Find out the BRAND NEW 100ft ethernet cable I bought from Amazon was defective. I tested with another cable and it switched to wired backhaul shortly after...thanks for the help!!
bmxsteve
Jul 29, 2020Aspirant
Jul 29, 2020Guru - Experienced User
Glad that was a simple fix.
Mark your thread as solved so others will know.
Enjoy. :smileywink:
