Mouskowits71
Dec 13, 2021Aspirant
Orbi RBR50 - 2.4GHz smart devices keep dropping off
Hello, I have an Orbi RBR50. I have a few smart devices like light bulbs that only use the 2.4GHz channel. None of them can stay connected to the mesh network regardless of how close they are to ...
Dec 13, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
- Mouskowits71Dec 15, 2021Aspirant
Thanks for the fast response.
Yes, the firmware is up to date. The bulbs are now pretty much all in one room. What's weird is now I can't connect to any 2.4GHz bulbs except one. I reset the rest and tried reconnecting them, but no luck even getting them back onto the Orbi. I plugged in an old 2.4GHz router to the Orbi and that worked so I don't think it's the bulbs.
If that changes anything, please let me know.
In the meantime, I will definitely try each of your suggestions.
