Tden3522
Aug 28, 2024Follower
Orbi RBR50 - Adding an additional RBR50
I have an Orbi RBR50 Router with 2 RBS50 satellites. I purchased an additional RBR50 to add onto the system, but it cannot be found on the wireless network. Since it is a router, can I not add it to ...
Aug 29, 2024Guru - Experienced User
you'd need a satellite to integrate with it.
I know some of the versions of the router could have firmware forced to them to run as a satellite. You won't find it on the official forums and it'll void your warranty
